reverse not working
patou241
gabon
Hi Everyone,
I have a landcruiser model vdj 200. the reverse is no longer working. is anyone already faced this issue.
thanks
Hi Everyone,
thanks
Have you recently been through water, I had this trouble in Romania after being stranded in a river and water got into the auto box.
Is it an Auto Patou? If so, with the engine running and the gearbox up to running temperature, cycle through all gears and reverse, then, back in Neutral, dip the auto box and check the level of the ATF. It should be between the marks marked ‘hot’.
Hi Everyone,
thanks
Valve body or transmission ecu. Check the solenoids out first then the feed to the solenoids when you engage reverse. after that you've got a stuck valve in valve body. Either way could take a bit of time to diagnose, just fitting another gearbox may not be the answer either.
