Roof Racks - Where to buy?
Crab
Hi All,
I'm looking for a roof rack (or failing that, roof bars) to fit my KZJ70 (3 Door).
According to #Crushers "the LJ70 tub is exactly the same dimensions from the firewall back to the rear doors. so if you order a roof rack for the BJ70/LJ70/HZJ70/PZJ70 it will bolt onto the KZJ70 tub. anything forward of the firewall is different between the LJ/KZJ70 and the others.''
Any suggestions where I can get a roof rack that will fit a 3 door 1995 70 series in the UK/EU?
Thanks in advance!
Pete at HazFabs would make you one, his racks are excellent. Check out Hazfabs on Facebook.
I had a rack off an Jap import 80 seriws on mine, had to bend thw brackets a little to fit, otherwise perfect
Thanks for the recommendation - I'll check them out!
