Howmanygoes
- Jan 14, 2019
I am looking to add a few extra lights and circuits to my roof top set up. I am limited on space for running cables up and was planning on using a common earth with branches off once it’s up to the rack.
Would the cable thickness be based on the same method as a positive, ie. amp requirements and distance. As a shared earth does it need the total amps if everything was on
Ie. 50” light bar 25a + 5a working light +5amp usb charger socket. Totals 35a. So 35a “riser” plus branches of 25a,5a,5a (subject to distance)
Alternatively should I earth them to the roof rack mounts if I have continuity and just run the positives up?
