Yesterday I removed the coolant bottle to get some room to change the batterry. I found this cable hanging about. Any ideas what it is? Should it be connected to anything? Thanks as always.
Had a rumage in that area on mine and cant see anything like that either loose or connected. I have the 24vlv version with the intake heater but the connections are nothing like that.
Sorry I cannot exactly answer your question, but if you look at the plug it has corrosion in the pins, so has been there a long time, so I suspect it has not been plugged in for some time if at all, so have a look round the area to see if there is a corresponding plug, and of course if every thing is working should not be a problem
If everything works as it should i wouldn't worry about it Mussy because Toyota are known to use the same loom for different spec and different countries hence some were left with dummy plugs that serve no purpose .
I can't be sure but i think maybe i had that plug in my 97 uk amazon 80 and because the pins were rotten i cut it off and wrapped each wire leading to it individually so they can rot no more nor touch each other . I had long since forgotten about it .
There’s lots that aren’t connected Mark. I’ve just heaved my coolant bottle out from the drivers side and cannot see a plug like that. As said, it’s been like it a long time and would have something not working if it had a home. I think you can let it be and sleep soundly.
There is a temperature sensor on some models fitted below and left of the coolant tank, it is used to modify AC output on climate controlled models, a possibility?
Depending on length, could it reach the air cleaner body, if so it could be for the blocked air cleaner element sensor option?
