Gr8Yota
- May 11, 2017
Stick them in the washing machine Ed. Wait till the wife goes out though or things could get messy.
Excellent vid BTW, I often add a bundle of chain to a shackled join to check any breakages. Got a couple of chunky soft shackles now so don't lug the chain around with me any more.
Need to put them in a pillow case or a duvet cover so that the holes in the washing machine drum don't damage the outer...
That's true, I'm pretty sure I haven't met your good lady Ed. This either means she'll be totally at ease with shackles and ropes in the washing machine… or you're screwed the moment you get a soft shackle as she knows it'll be in the washing machine at some point.And I don't think you've met my wife... she used to work in Outdoor Ed as well, so understands what goes on!
Gr8 nice work there but can you tell me where you got the protective sleeving from please
Thought I recognised it! Hydraulic hose sleeving like this would probably be excellent.View attachment 137700
I also use the outer cover from 1tonne endless slings which is good too
My only concern is with dirt working into the rope cores (coming from outdoor ed, the number of times I've washed and worked dirty ropes to clean them completely it's not a fun job) but I think that there were some other issues that were found in the tests that were done in Australia with them.
Found some Soft shackles that don't seem too expensive.
http://www.4x4goods.com/shop/winching-products/577/
