Trevor
- Jul 25, 2010
Trying to work out whats normal or not on my LJ70
1) The oil level indicator works when I turn the ignition on before starting and indicates the oil level. Once started the needle falls away completely out of sight. Is this usual or should it be indicating level all the time?
2) Whilst the charging needle stays above halfway in the white section, the charge light is very faintly glowing red, needle drops but stays in the white as I add load by switching stuff on. The faint lamp glow does not change whether I'm loading the electrics or not. Alternator problems or normal?
3) Not having had MT's before, I get a whine with what sounds like a slight oscillation between 35 and 45 MPH, I thought it might be a wheel bearing but can't detect any play or gritiness. Not sure if it's tyre noise, transmission howl or what.
Any ideas chaps?
Any ideas chaps?
