ByronJ
- Jul 7, 2012
My 1994 80 series has just failed its MOT because the speedometer is not working. No speed displayed and the odometer does not turn. Assuming it was the Hall speed sensor I bought a 2nd hand one and swapped it in. Still no speedometer!
So I did what I should have done in the first place and tested the sensor.
The sender is pretty easy to test. There are three connectors coming out of it. Using the colours on the wiring harness, yellow is the +12v supply, brown is earth and the red with green strip is the signal wire. Utilising an old plug and some screw connectors as below I supplied 12v and put a meter from the signal wire to earth. Slowly turning the armature I was able to detect 12v at four positions per revolution with the replacement and original sender.
