STALLS WHEN ON AN UPHILl INCLINE AND IDLING
Harris Raphael May 15, 2019
  1. Harris Raphael
    Harris Raphael New Member I am in great_britain
    3
    0
    1
    Map
    Hi - my first post so hi to all and thanks for any help.
    I have a 2005 120 series which in the last two years has developed a fault where when I stop the car on an uphill incline and idle for one to two minutes, the engine cuts out and then won't re-start, even if I get the car onto a flat surface. In trying to start the car, the engine tries to turn over but won't catch.
    I have done some major work to try and resolve the issue including replacing all the injectors (at Toyota's advice!), but the problem persists.
    Any helpful geniuses know the fix???
  2. fbnss
    fbnss Well-Known Member Supporter I am in england
    2,484
    1,598
    113
    Map
    I'm sure someone else will pop along shortly but is air getting into your fuel line and the diesel draining back to the tank when on a hill?
    Harris Raphael likes this.
  3. Harris Raphael
    3
    0
    1
    Map
    Thanks fbnss - it goes up hills absolutely fine. It is only when I stop on a hill and idle for a while that the engine cuts....! why would idling cause the problem? Fees like it should a fuel starvation issue but I am the world's worst mechanic. Also - why would it not then re-start once I have got the car on to flat road (by rolling or towing it)?
  4. fbnss
    2,484
    1,598
    113
    Map
    Beyond.my knowledge im afraid but I'm sure someone who knows will mention scv or something like that.
    Higgy likes this.
  5. Higgy
    Higgy Well-Known Member Supporter I am in denmark
    1,760
    1,133
    113
    Map
    Next time it cuts out, Prime it up first with the Plunger on the fuel filter Housing.. Then try it. If it starts pretty easy Then you do have a fuel issue /Air getting in etc etc,... PS keep priming the plunger till it goes Hard...
    Firewout and Harris Raphael like this.
  6. Harris Raphael
    3
    0
    1
    Map
    Thanks Higgy -will do.
  7. Firewout
    Firewout Well-Known Member I am in belgium
    723
    373
    83
    Garage:
    Map
    I had the same issue with my 80. It was a small air leak in the injection pump. Follow higgy's advice with the priming to test if this is the problem.
Share This Page
    Dismiss Notice
