Does anyone know what the increments on the stock volt metre on dash 9v then x7 Mark's then 14v
V Verrelli New Member Joined Feb 6, 2019 Messages 4 Country Flag May 5, 2019 #1 Does anyone know what the increments on the stock volt metre on dash 9v then x7 Mark's then 14v
StarCruiser Well-Known Member Supporter Guru Joined Oct 7, 2014 Messages 12,046 Garage Country Flag May 6, 2019 #2 Verrelli said: Does anyone know what the increments on the stock volt metre on dash 9v then x7 Mark's then 14v Click to expand... 14-9= 5 5/7= 0.7142 volts per Mark (bit of an odd division but who am I to argue?) It’s an indication rather than an accurate meter. If you want to know charging voltage you should use a multimeter on the battery terminals. Post up a picture, I’ll take a look. Hi and Welcome by the way.
