Starter motor bolts
Springate’s
Anyone know what size the heads are on the bolts that mount the starter motor to the bell housing? Ta!
Turns out they’re 17mm and the top one was what in weightlifting circles would be called a ‘1 rep max’ to remove! Well it was for me using a 9” ratchet (breaker bar wouldn’t fit and don’t have suitable extensions!).
I was able to remove the starter, strip and clean the solenoid which has solved the intermittent starting issue that I’d been having. In fact it sounds like a much more powerful start all together. I believe Roughtrax supply a solenoid replacement kit but I simply cleaned the old one up with a flap wheel.
I used the following for guidance:
https://youtu.be/PIlso-1YR_0?si=ASGV_cOvc1LDYIGK
