- Jun 30, 2011
Hey guys - hope this is of some use to someone - Pics and help for removing the starter from the D-4D engine in a 90
Mine is a late model KDJ95 - got the starter reconditioned yesterday - cost a total of €85 (about £70)!
1- With the 90 up on an axle stand remove passenger side front wheel - then remove plastic panel shown below for access to the starter
2 - Remove the main power lead from the starter (12mm socket) and disconnect the ecu connections
3 - Using a 17mm cranked spanner - undo the top nut until it is loose enough to turn by hand - followed by the bottom bolt. Access is tight and only expect 1/8th of a turn of the spanner - patience required.
4 - Once nut and bolt are out - starter must be taken out through the top - so remove the air filter housing. This is also tight and you may have to unclip a couple of the hoses to move them out of the way. It helps if you bring the starter up gear end first.
5 - Get starter reconditioned by auto electrician - in this case clutch was gone and brushes worn.
6 -Replace starter in reverse procedure - again patience required - having big hands is a disadvantage here - thakfully mine aren't shovels! Tighten well and use a torque spanner preferably to correct settings (didn't have these to hand but judged it ok from years of changing heads on tractors)
Hope its of some use for others - not half as hard as i thought it would be from reading on here!! whole job took 45 min (not including auto leccy of course!!)
Bob
Bob
