OK jobs going well. All 4 shocks removed, rear springs changed over and rear shocks installed. I'll do the front next week.
While it may be straightforward technically, getting the bolts off the top of the shocks, especially the rear was a real PITA. I found I had to use the bottle jack in-between the axle and the bump stop to get an extra few cm's to get the springs swapped out, but all good.
Anyway, while doing it I undid the drop links and found the rear ones are looking pretty bad so i'll need to change them.
Whats the thinking on extended drop links? Do they make a difference? Are they any negative effects to consider? (Lift is still 50mm which it has been for the last 10 years with standard links)
