Tacho
justlearnin
australia
Hi I have a 2001 HZJ105 my tacho is intermittent and I am a after some ideas on how to problem solve and fix it. I have checked the cluster and it is sitting in ok.
Hi
I have a similar problem, had the fuel pump replaced and now the oil gauge and tacho are not working. The mechanic had the dash out and tested and basically said that this was a common problem with the standard 105 series, he also replaced the oil senor but still no joy.
I was also told that the tacho can not be fixed and had to be replaced.
Sorry no solution from me, I was also told to check around the fuel pump, but I'm no mechanic
