- Mar 1, 2010
The Toyota Manual says 103 ft lbs. There would be at least another 50% safety margin on top so they should take at least 150 ft lbs before snapping=faulty wheel stud.
It also didn't actually torque up to that ... it sheared well before the click of the torque wrenchThe Toyota Manual says 103 ft lbs. There would be at least another 50% safety margin on top so they should take at least 150 ft lbs before snapping=faulty wheel stud.
Hmmm brittle failure and the boat looks stretched from about 3 threads down. I wold test another in the vice and make sure the torque is being applied centrally with a short socket. 109Nm = 88Lb/ft so it shouldn't have failed.
Out on a local run with that sounded like a wheel bearing on it's way out but was becoming worse much quicker (within miles) first onto more rumbling on corners and then onto a full wobble through the steering. I left it a little longer than normal to check as I was so close to home - this nearly proved a very costly mistake!
As my 80 was at the mechanics for 5 months(!!) and just had an MOT (where I don't think they would have touched the wheels) I have no idea when the wheel nuts where last checked or when the wheel was removed.
New wheel studs all around have been ordered.
I would have thought a nut would be OK if it was a close fit on the threads. Studs however are under constant tension and flexing and any stud, in the end, will fail due to metal fatigue.
Seriously poor. It looks like cheap bright mild steel whereas I suspect the genuine Toyota stud was/is made from a steel with a much higher carbon content. I'd bet you a night in my local curry house the stud in the photo was made in India or if it came from China it was purchased on price not specification.
I've worked on cars since lat 50's and have never had a broken wheel stud or bolt but I have always greased them. I think if they are rusty there will be a twisting action which the bolt or stud is not designed for.
OK so I had a prompt reply from Milners after Grant got less than a satisfactory response. This is what they said.
They acted immediately, with one of the directors actually replying to me out of hours yesterday.
Test run with a steel tube (wall thickness 6mm) and a standard wheel nut we sell
Torqued wheel nut up to 170NM (125ft-lb)
The wheel stud has not snapped but showing signs of stretching as sharp edges appearing
Looking at the torque figure we have for a landcriuser is states that the max torque figure is 149nm (110ft-lb)
It does say in the manual that the torque figure goes from 80 upwards we can only assume that this is to do with if you have used say copper slip and this will reduce the figure by 10-15%
We have tried to do a good test on these I know its not the real world but I wouldn’t be lying if I said we do sell over 5000 a year of these studs world wide
