AndyCook
During Morocco trip my landcruiser developed a dull "thump" - "knock" noise when going over bumps
it seems to be drivers side rear.
I have check ARB links, shocks, coils springs, and even replaced the coils when we got home with the less stiff ones i use when not loaded,
no cracks on axle/suspension mounts
top control arms new, and still secure
panard arm mounts look ok and arm seems secure
there was slight play in drivers side lower control arm, fitted new polybushes tonight, noise still occurs
the bolt on control holes didn't look oval, and there was no evidence of disturbance of dirt around the bolt/nut head to indicate it had been moving
will do passenger side and panard arms too as the bushes are perished.
fuel tank straps secure and no movement, same with asfir bash plate
swung exhaust around - noise didnt occure
jack is secure and all boot storage system
drivers side rear chassis/body mount looks a bit perished, but i wedged a piece of wood between chassis and body,
noise remains
rear door seems secure and spare tyre on tight and has been swapped with GG AT2 since i got back from morocco
driving me mad, anything obvious i have missed?
noise remains
