I am very tempted to be fair. How hard to top up sim card? How do you check the area coverage as i hear some are better in certain parts of the world.
Stu
Topping up is easy now. You can do it on line. Used to be a bit of a faff. But now with a password etc you can pay directly OR you can enter scratch card numbers. There are two types of SIM. Northern Europe which is the one I have and it works ok and slightly wider coverage for Africa / Aisa as per Warren's map. It is not the best coverage but it's one of the cheapest. The satellites are sort of clustered over Dubai or some such and as a result are pretty low in the sky for the UK
Very easy to top up like Chris said. If you put a GSM SIM in that just means you pay for the calls using the GSM SIM contract, it is still using the Thuraya satellites to make the connection so still subject to the coverage areas on their map. Your GSM SIM provider will bill you as if you're roaming in Dubai iirc
