Hi Nico,
According to the VIN it is a BJ40LV-KC. Built in September 1983 as LHD, 3000cc B engine , 4 speed without roll bar. So it looks to be very original.
With the draglink looking a little tired, it is worth checking the bearing in the centre arm assembly - it is situated just behind the front bumper. The bearings do wear but (I think) Spectre (sor) do a brass bearing set up. They also do the original hub caps as the wheels look to be original split rims although the tabs appear to have been removed.
Rodger
Hey Rodger,
Thank you for the comments. I noticed the draglink as well. I will be sure to inspect that and ask the owner if he has had any issues with it. Any idea how difficult it would be to instal a new one? From what I was told and can tell, the wheels are original; not sure what happened to the tabs though. With a wire brush clean up and undercarriage coating plus a fresh set of caps, she sure would be looking good.
I have reviewed all the paperwork with this cruiser and everything checks out in my research and what you all have stated. I appreciate the comments and help. Just curious though, where do any of you feel the price point should be at?
