warrenpfo
- Jul 21, 2010
I had to replace a faulty brake bulb yesterday and after removing the drivers side light cluster came across a jumble of wires and a little black box sitting under the light cluster. On further inspection and some googling I found out the little black box is supposed to emit a sound when I have a trailer connected and the indicator on. This is not happening to thought I would remove it and follow the rest of the jumble of wires. It appears that who ever installed my tow bar and its electrics (its a Toyota tow bar) seems to have either had a rough night before or was just very sloppy in their workmanship.
They seem to have punctured one of the rubber bungs so that they could feed a wire to the rear light cluster and then used those plastic clips that have a small metal rib in them to T off the existing wiring harness to one of the rear light clusters.
I wondered how other people have done their tow bar electrics and if there is an off the shelf harness one can buy that just plugs in to the tow bar electric socket that hangs under the rear of the car.
