ModelMakerMan
- Jun 25, 2011
Just found a slight hitch (pun intended) with my tow ball now Ive raised my truck Ive also raised the tow ball height (I know its obvious but I hadnt considered it till I came to tow something). The standard height for a tow ball is 16.5" from the ground to the middle of the ball my ball is now about 22" of the ground!
I have the standard tow hitch setup (or plough as its best used), only Ive now removed the rear bumper and steps and of course raised it 2" and put 33" tyres on it. If I widen the lower mounting holes that usually bolt into the bottom two of the recovery point bolts on the rear cross member I could move the hitch down to about 20" and it would still be bolted on with 4 bolts which would be more than strong enough to tow the 750kg tupperware box on wheels I would be towing but still too high really.
Im wondering what others have done as a more permanent solution on their lifted vehicles? A removable option would be best as I dont want to mess up the departure angle.
