Transplanting 1HD-FTE engine into a HJ75 pickup
Mike Michael
south_africa
I have purchased a 1HD-FTE engine complete with wiring harness and ECU. Is there anyone out there that can advise how to make that engine run on a 'test bench'?
Thank you Andy. I am determined to make the new motor run on on the bench before I start with the installation, I just need to figure out how to make the ECU run the motor efficiently as I have retained the manual gearbox
Hello , im planning to do the same swap into an RJ70 1988 , where you able to manage everything good? any tips before i start the swap?
thanks
The only thing I can add is I think you will have to have a gearbox attached in order to mount the starter motor.
