thelal
- Mar 11, 2010
1997 petrol USA FZJ80 300K
starter contacts redone in last 15K miles
been "fixing" truck last month or do and batterys (dual) taken out + lots of inside as fixing sunroof leak.
Put all back together but won't crank over.
Not the battery, as full charge, even had 'jump' start via another car and replaced main battery
It won't start, doesn't even attempt to crank
Methinks its electric, fuse or something
Checked NSS connector near transfer case and that seems fine (no corrosion and wires look ok); other than me breaking the connector - duh!
All fuses, relays seem ok in main engine and under dash.
On the dash when put in OK position have check engine, brake light (do not have tranny, or low oil light) indicators
I do no have any sign that my alarm (red light on dash) is activated and disconnected the 3 main wire harnesses to the RS3000 under the drivers seat but no difference. Put back together but no difference
I tried to reset the alarm (push in small green button on side of alarm for 3secs+) and pressed two of my fobs but nothing.
So concern that the alarm has something to do with it as it controls the IGN switch connector to the starter motor. I can't tell if mine is working or if its dead or how to bypass
Anyone with an RS3000 alarm? Can you tell me what happens (led light come on, what sequence) when getting ready to start (just before) your truck. How can you tell the alarm is working (other than response from a Fob press)
Ta
Ta
