JimmyLJ71
- Jan 30, 2011
I have an Lj71
When i first got the truck after about a year it started to use alot of oil until at one time the oil light came on a couple of times , i found out that the turbo had failed , there was alot of play on the bearing , i then replaced the turbo with a good used one , later on i also had the engine rebuilt .
After running the engine in very carefully i have recently been on a trip to Morocco where the engine appeared to be using alot of oil again , im getting very worried having spent alot of money having it rebuilt knowing i had replaced the turbo , although having said that it was running sweet .
Upon coming home i decided to service it as i usually do but thought i would check the turbo , it had gone again !!!.
Is this bad luck or is something causing it, it was under alot of stress in Morocco
