Updating AHC springs
Howmanygoes Jun 9, 2019
  1. Howmanygoes
    Howmanygoes Member I am in england
    117
    30
    28
    Map
    On a recent trip we may have overloaded the truck slightly as the height indicator was dropping into low without adjusting the position sensor.
    AHC works normally without load.
    Is it possible to up rate the system to a heavy duty spring as an interim till I can cough up for a full system swap out?
  2. Lorin
    Lorin Well-Known Member
    1,195
    206
    63
    Map
    IIRC it is. Some good info on Mud about this. Worth a bit of reading over there.
  3. big-yin
    big-yin Active Member I am in uk
    52
    14
    8
    Map
    Following this, mine dropped to low setting during recent camping trip with 6 of us in the 100 and towing a trailer tent. I'll have a look for the information on Mud too, thanks Lorin.
  4. Jacob100
    Jacob100 Well-Known Member Supporter I am in uk
    558
    289
    63
    Map
    That’s the only time it’s ever happened to me. Pulling away with a camper trailer full of soaking wet canvas.
  5. Ian Rubie
    Ian Rubie Moderator I am in uk
    924
    86
    48
    Map
    King Springs KTRS-79 are the most commonly recommended upgrade springs for AHC equipped 100's.
    I bought mine from Sparesbox in Oz. Delivery was fairly fast.
  6. Jon Wildsmith
    Jon Wildsmith Super Moderator Supporter Guru I am in england
    6,663
    110
    63
    Garage:
    Map
    if it's for an occasional load rather than constant I'd use new standard spec springs with 30mm spacers and air bags. If you don't let the AHC carry enough of the load the ride can get very bouncy because there isn't enough damping.
  7. BobMurphy
    BobMurphy Well-Known Member I am in scotland
    1,432
    429
    83
    Map
    I replaced my AHC Globes a couple of years ago. There are three grades out there - standard, heavier duty and really heavy duty.
    I used the middle grade.
    Towing a 2.6 ton mini-digger on my Plant Trailer the back was dragged down because the trailer hitch is a bit low. If I set the height to 'low' it wouldn't come back to 'normal', but if I left it in 'Normal' it stayed there. Whether this was a function of the globes I'm not sure, but the springs are soft and allow the suspension to drop to 'Low' so don't expect them to help with a heavy load much.
    (My plan is to change the 50mm ball hitch on the Ifor GX 106 to a Clevis Hitch then use the pin on the 5-ton Dixon Bate Combination Hitch which will allow the trailer to sit level when the '100' is at 'Normal' height).
    Bob.
  8. karl webster
    karl webster Land Cruiser Club sponsor Promoted Company Guru Land Cruiser Club Promoted Company
    5,290
    876
    113
    Map
    I do the airbags if you go down the spring route.
Share This Page
    Dismiss Notice
