Yes they do for brake servo vacuum.....No I am assuming the 80 have a vaccum pump fitted to the engine.
So I have 2 issues that I think could be related to vaccum issues but happy to be told hmm no.Yes they do for brake servo vacuum.....
Is yours failed or do you think it's failing ?
??I thought the vacuum is used to open the turbo waste gate and dump boost so if there was little or no vacuum the turbo would over boost, opposite to what you are experiencing.
Where is the exhaust outlet for the vacuum system?
Yes ...servo assist so the pedal will feel like you're pushing hard and nothing is happening ..... I think the reservoir holds enough reserve capacity for 5 or 6 pushes before the pedal effort is entirely right leg generated .... have a play in a safe spot rolling down a hill in neutral with the engine off..... you then realise how much work the brake servo is doing.I seem to recall vacuum being used on the boost circuit on the FT's. Altitude compensation istr? Creates vacuum under the boost compensator diaphragm to vary the effect of boost on the diaphragm? There are solenoids controlling when it's applied. So it is possible that loss of vacuum affects the turbo on an FT. Could just be a split vacuum pipe or an electrical problem on the turbo fault.
Doesn't loss of vacuum make the brakes hard work rather than not very good? i.e. it's an assist, but if you push hard enough the brakes should be effective?
I would think the terrain tamer brake servo would be a better mod IMHO....I chanced upon this a while back and it seems popular on MUD
80 series Brake upgrade - [Leaving Land Cruiser Club]
