Personally I would be fitting a new one rather than a 25+ year old part as age is a major factor in the failure of these.The outer part of the crankshaft pulley that has the air con belt on it separated from the inner part. As a result I need a replacement. Does anyone have one?View attachment 157033
Failure of this can cause crank damage
All sorted now - I bought a new one from Roughtrax. Easy to fit once you've unbolted the fan to give access.
Thanks to chapelgate for the link and thanks to Karl for his quick response even though I didn't go down the used route in the end.
Only another 20,000* parts and it will be new!
* I've no idea how many parts make up a LC
