Hi Guys
I've got a weird electrical problem with my HZJ79. I've done a series of tests:
I've also had the wife press the pedal down while I wiggle all the harness' and wires I had access too, that did not do anything.
At this point I'm thinking a ground wire is broken somewhere and some weird ground currents is causing other circuits to be energised.
I'm trying to work out a plan of attack for the coming long weekend to suss it out and would really like some suggestions.
-Vinnie
- If the headlight are off and I press the brake, the brake lights come on but also the instrument panel's background lights come on and the "lights on warning" alarm sound.
- If I take out one of the brake light globes and perform test 1 above, everything "seems" normal. (It can be either globe, and I have swapped the globes between the two brake lights.)
- When the head lights or diving lights is on and I press the brake, the instrument panel's background lights comes on and the lights on warning sound, but the brake lights do not come on.
- If I unplug the harness that goes to the rear of the car (include all the rear lights, the internal light, door switches etc.), it again seems normal. This however could just be masking the issue, as test 2 seems to indicate some dependence on the current draw.
-Vinnie
