That mig welding forum is good. Ben near you there is a good welding shop
http://www.mig-tig.com worth going and looking at the machines down there, especially hire costs.
Really you need to spend about £600 for a useable machine. But for someone that is learning to weld and wants good results asap you will need to spend £800-1000. Get an inverter machine not a transformer as they are much better as they are lighter and smaller, to get the same punch from a transformer machine it would have to be a in a wheeled cabinet type.
Buying a machine 2nd hand could be risky if you don't have much experience with welding as it will be hard to know if the machine is faulty and welding is hard enough anyway without having to fight the machine!
I used to have BOC gas but worked out expensive for me, I now get a deposit bottle from Motor Parts Direct, which seems much better value. You need argon+co2 for mig, pure co2 makes things difficult. You can weld stainless with argon+co2 as well which is good.
The first machine I bought was a cheap £200 Chinese one. It gave a poor weld and only lasted a couple of years before it all bunt out. Luckily we have a good machine at work so I knew what a welder should behave like.
I bought this machine last year:
It is a synergic inverter welder, it does mig/tig/arc. It was pretty expensive but it is the best machine I have ever used, better than a transformer cabinet welder and in a different world to the Chinese machine.
The screen shows how the welder is set up, you can see it has been welding Stainless, CrNi, with Argon Co2 gas. Using 0.8 wire, and the stainless is 1.0mm thick.
You set all these parameters in the menu, you can save common ones etc.
Then when you start welding it automatically adjusts the amperage as you weld, continuously.
The other good thing is it lets the gas flow for a pre determined time after you have released the trigger, this stops oxygen getting to you cooling weld and spoiling it, but more importantly on bodywork you can do small sections and then let off and the gas will cool the very thin bodywork you are welding stopping burning of holes. This is the best feature really on the machine as it makes doing bodywork much much easier and quicker.
It is very good for very thin stuff and very good for heavy stuff, which is great for Land Cruisers (body work and bar work!).
If you want to have a go on with my machine let me know!
