went car shopping today..
chapel gate
Promoted Company
I am in england
May 26, 2014
4,114
2,573
113
near, leek staffs.
Ever get the feeling your on a bad run?
Went for a drive around the block, all good, then brake fluid warning light came on..
Got back to base and fluid was pissing out from the front left.
Corroded lines. Replaced with copper.
Yeah, that's right. Broken spring too.. :icon-rolleyes:
Alls well after a brew and cheese and ham toasties :thumbup:
After bleeding all eight bleeding nipples brakes are great.
Springs on order..
Grimbo
I am in great_britain
Dec 3, 2016
497
450
63
Inner axle oil seal looks like it may be leaking ... ;-( the seal between the centre axle and the UJ ..... check it's not the hub breather though .
I looked at a 1200 the other day with similar oil leak and it was coming from the joint between the solid hub breather pipe and the flexy rubber hose where it joins onto the centre axle .....
chapel gate
Promoted Company
I am in england
May 26, 2014
4,114
2,573
113
near, leek staffs.
Oooh, that copper brake pipe is a bit squidged . . . Will be OK though :whistle: .
It never ends, does it !
Bob.
yeah, i pushed it that bit too far. should be ok though. i always find those short, sharp bends a bit difficult. i also have this OCD thing with following the shape of the original as close as possible...
your not wrong there. im hoping one day it will, but i doubt it.
Can i have HP sauce on my toastie ?
sure! will be ready in about 30 seconds..
I had a radio bodied 404S. loved it, used to just sit in the cab and smell it!
i know exactly what you mean. done plenty of cab day dreaming myself.
correct. both of the metal breather pipes that screw into the portals are corroded and leaking. there on order with the other stuff.
clivehorridge
I am in romania
May 23, 2012
14,871
4,870
113
Comarnic, Romania
Late last year I had my rear axle breather block up, couldn’t understand so much oil spray under the truck at the back, or where it was coming from.
10 minutes with my trusted service guys had it diagnosed and fixed with a new breather install, at no charge...
Couldnt argue with that now, could I?
chapel gate
Promoted Company
I am in england
May 26, 2014
4,114
2,573
113
near, leek staffs.
New spring fitted.
Old breather hard lines.
"modify as required" according to merc.
Accelerator pedal was a bit sloppy, replaced the worn bushes with new,
Old and New air filters. Long over due replacing.
The thin one sits inside the not so thin one.
back on the road now. got some jobs for her next week. then the turbo will be coming off for a rebuild before fitting the new exhaust.
Grimbo
Dec 3, 2016
497
450
63
That reminds me of some of the combine parts we used to get from the factory...... the original pipe would be 5/8 diameter and 4 m long and a complex series of bends in multiple axis and both 90 and 45 degrees ...
The "new" original part would be a 4 meter straight length of 5/8 zinc plated tube.... oh how we loved doing multiple mods and repairs involving miles of metal hyd pipe ;-)
  • Like
Reactions: chapel gate
AdBlock Detected
