Wheel Spacers
Try and source some 18" wheels, I think were fitted as standard on some later models, Dont know if UK spec trucks had them, But some were fitted as standard..
Yep, 18" were fitted from the second facelift, up from 16", all UK 100 were fitted with 18" wheels from the second facelift late 2003 if I recall correctly.
Good Luck if you look for some 18" as they are as rare as hen's teeth, in used condition, although they do come up on eBay now an then.
Don't quote me, I think you could fit the 18" wheels from a 200 series, there were some new wheels with tyres fitted on eBay recently, seller said they were removed from a 200 that had been fitted with run flat wheels and tyres for an UN armored upgrade 200.
Is the only advantage to 18's being a greater selection of tyres or are they wider as well?
I want to increase the overall diameter and width of wheel and tyre not just a bigger wheel with lower profile tyre.
