wheels
The PCD (pitch circle diameter) is the same but the central hole may be to small. Certainly my wife's Shogun wheels wont fit my LC.
Roger
PCD is the same, Centre bore is 70mm I believe, where as the Landcruisers are 110mm...
If you run spacers then they will work. :thumbup:
cheers for the replies. Running on spacers. Might try and get hold of a wheel locally and give it a go...cheers again. :thumbup:
25mm spacers or above will enable them to fit on the back. Because of the hub protrusion, they will not fit on the front.
Roger
