I'm sure pic laden instructions thread would have been well appreciated on here Flint , i guess its too late for that now
A bit sketchy on pics (slow upload here), and far from definitive, but a few bits and bobs. Pretty much straight forward to get the diff out, jack up, stands under the chassis (with a bit of 2x1 to save the finish) and wheels off. Undo the four bolts that hold the lower ball joints to the wishbones and ease the drive shafts out of the diff and extension tube, I started them off with a cold chisel (gently) and popped them out with a crow bar. Disconnect the prop shaft after marking it and the diff flange (probably not really necessary if the pinion and crown wheel are coming out anyway, will check prop phase on reassembly). As my preload was out, I then took the diff flange off to make it easier to manoeuvre out. Get a trolley jack under the diff to take the weight and undo the two front mount bolts and the hex bolt (12mm) at the rear. The thread that sticks down from the rear mount through the cross member means the rear of the diff has to be lifted before it'll move forward, clearance with the diff flange on would make this pretty tight. Lower diff on the jack and have a cup of tea. The manual will now tell you, after taking the seal and splash ring out, to remove the outer bearing, special tool needed which I haven't got, so I pressed the pinion out after removing the extension tube, side cover (ten bolts) and diff case. This is what you'll find with the cover (side bearing retainer) removed.
It seems that I've been lucky, ring gear and pinion look fine, no chips or excessive wear (odd reflections from the flash) diff gears fine.
Pinion bearings and races not so good, so will be replaced together with a new crush sleeve. Side bearings and races seem fine, so I think I'll leave things be until it's all back together and the backlash and contact pattern are checked. Well, it's a start anyway
