Chris Green90
I have an aerial up/down switch in the cab of my 90. I thought it would be nice to be able to operate the winch from inside the cab, plus with the winch mounted using one of J66p's mounts it is a little awkward getting the controller plugged in. I figure I could just leave it plugged in all the time and run it from the switch in the cab.
Do you think that it will just be a case of finding which terminals close and open as and when the buttons are pressed then wiring the controller cable to them. can't see there being much voltage involved as its only a signal, surely the winch has the necessary relays or whatever inside to turn that signal into enough power to run it.
