Howmanygoes
- Jan 14, 2019
So auto electrical guru's
I had solar 100w on previously into my CTek 250sa.
I now have a new RTT coming which is prewired for 300w solar. The instructions say to ensure regulator can take 45v that a 300w panel produces
My previous cable was 4mm2 "solar"
I have some 6mm2 thin wall (53a) and planned to use this due to the run required.
My CTek has an input voltage, max open circuit solar panel voltage of 23v
So my questions
Will the 6mm be suitable without the extra insulation that the "solar" cable provides.
Will I need to buy a new mttp controller?
Should I choose panel first and work backwards.
Cheers in advance.
So my questions
Cheers in advance.
