- Sep 11, 2013
Folks have a few led spot lights ( at the rear) to wiring in and also looking to get a large LED light bar for the front. I have all the switches with the different symbols on for each set of lights, think the switches need a feed as well so that they can be seen when you turn on the lights.
I have bluesea fuse panel in the back as well.
So the question was, what is the best way to wire this altogether??
Do I need a relay per circuit? If all the switches are together beside the drives seat do I make up some kind of harness?
Any info would be great.
Craig
Craig
