MisterCruiser
- May 28, 2014
I have a condensation problem, the front windscreen gets totally saturated with condensation and the inside of it freezes along with the outside of it obviously. The sunroof also has same issue, large droplets on it and freezes. I currently have the headlining removed to examine the sunroof for leaks etc, mine has no drains version, anyway I'm going to hose water over it tomorrow evening with a mate to see if it leaks.
In the hard frost this morning, I also had some condensation and frozen droplets on the roof front to back.
I've googled and researched this, have checked the following:
- no obvious leaks in footwells, under carpets, etc...
- coolant not dropping, no leaky heate matrix.
- no sign of any water pooling in the interior
Anyone got any suggestions to check what might be the cause of such excess condensation.
I have had the windscreen replaced a few years ago, it seems to be sealed ok, no obvious leaks, but I've read on google where some folk have remedied their condensation issue by getting their replacement windscreen re-replaced.
I closed all the cabin vents and turned the air to re-circulate last night when parked as I read cold moisture air could get in via them but made no difference, thing frozen solid this morning. My daily 2008 Golf was only frozen on the windscreen exterior in comparison, both parked same place.
If the sunroof isn't leaking, what else could cause this?
