110Ah Leisure Battery - Numax XV31MF CXV
Trevor
I have a nearly new (6 month old) 110Ah Leisure Battery - Numax XV31MF CXV, dimensions are 330mm length, 172mm width and 242mm height. Used for a solar project and now surplus to requirements. Looking for £50 and can bring to Lincomb if that helps. 2E1E3AC6-91FA-4909-B624-61696D53AAE8-639-000000AC4CF5BC00_zpsdc2d75aa.jpg 756EDBF9-E445-4E7B-B342-14C9057B0303-639-000000AC44E3836E_zps38b533aa.jpg1CE19186-BE02-4761-98F2-D7051F19998A-674-000000AF5B0CC189_zpse508b227.jpg 61884FA8-10D4-4C64-9447-1F84F38DD953-674-000000AF6320525E_zps68ee91db.jpg
Sold please bring to lincomb and i will bring some cash with me.
thanks stu
Cheers. I'll bring it along. Not sure if I've charged enough for this <groan> lol
Ok £50 and a beer sound better i have tusker from kenya so worth at least the same again.
thanks 3 batteries that is now. could power anything this weekend.
That was my very poor attempt at a battery related gag, but I like beer so you're on :)
Trevor, that's a shocker. Couldn't you take the lead and post it given the current climate; that's the acid test? Mind you, there's ample opportunity to hand it over on a plate really then he can take it ohm..
Chris, I refuse to take that post seriously. You don't know how to conduct yourself, must have been down the pub as I heard your missus ask you wire you insulate?
Trev, Trev - why so negative?
Surely we aren't poles apart.
But if you don't want to cell it...
groan... getting a bit weak there lead(s)
You OK Tony, you sound a bit flat. Sort of run down. Lost your spark? You can go through cycles like this.
hmmmmm. That's Shocking and the conversation on here is usually so electrifying.
Agreed. Sort of lost its fizz. Usually more people gassing away. We need to just distil why that might be. Perhaps they just need to vent something. Maybe blow their lid. On the level of course and up to the mark with a degree of gravity about the specifics
Sorry I cuurent keep up with all this tip top banter here. Theres a bit of a negative charge in the air :wtf:
You need to be a bit more optima-mistic and try and gel with us.
C
:think: I think this thread has lost its spark.
