roy
- Feb 4, 2011
From what i have found out the later 120 calipers and discs are larger than the 90 brakes and might make a good upgrade.
anyone know of any reason why 120 calipers, discs and pads will not bolt to a 90 hub ??????
apart from wheels size and dust guard.
120
pads
134.6 x 77.1 x 17
discs
Disc Diameter 338.0mm
Disc Thickness 28.0mm
Overall height 67.3mm
Centre Diameter 108.0mm
vs
90
pads
119.2 x 72 x 15
discs
Disc Diameter 319.0mm
Disc Thickness 22.0mm
Overall height 70.2mm
cheers roy
120
pads
134.6 x 77.1 x 17
discs
vs
90
pads
119.2 x 72 x 15
discs
cheers roy
