Hi all,
Have an HJ 61 Cruiser with a 12HT motor that won't shut down when the key is turned off and removed. The only way to stop it is to lift the bonnet and manually push the rod on a solenoid on hrs of engine. Solenoid has a vacuum hose going to it so I am assuming that once the key is turned to the off position, a vacuum activates the solenoid. Have searched in the manuals and found nothing associated with this problem. Has anyone else had this problem or can someone please point me in the right direction to fix it.
Thank you.
mike.
Thank you.
mike.
