Hi Guys
My 1993 LC 1FZ-FE (has LPG injection as well) has started it run ruff as guts and has a ticking noise so I did a compression test with the following results:
1 0
2 135
3 125
4 145
5 140
6 140
No compression on No 1 cylinder and the other cylinders are below spec (171 psi) or more is standard I think
(Motor has 383000km on the clock)
So I thought it be best to get a new head and VRS kit and replace the old head
Gear bought to date so far:
1 x Brand New After Market Cylinder Head (suit gas/lpg) (includes 12x new intake valves, 12x new exhaust
valves, comes complete assembled with camshafts/ buckets and valve clearances set) $1500.00 incl shipping
1 x Permaseal VRS gasket kit $383.00
1 x head bolt set $75.00
Now a thought just struck me that I'm going to all this trouble to replace the head but what about the block?
I'm assuming No 1 Cylinder has a burnt out valve as there is no compression and the other cylinders are on the way out hence the head
What if the rings are gone on No1 ?
The bottom end is also worn hence a new head old bottom does not make sense?
Should I have just pulled out the motor had got an exchange reco one?
Can I now get a short block exchange or just get my bottom end done?
Now I have not yet completed pulling off my old head just yet, maybe by this weekend I will have it done
Hence my dilemma......what to do with the block?
Any suggestions would be appreciated
Thanks
1 0
2 135
3 125
4 145
5 140
6 140
Thanks
