- Feb 2, 2013
I haven't looked into 1kd egr deletion with any great interest but as i understand it boost is managed by the ecu and so there is no traditional wastegate on the turbo , instead when off boost it bleeds the pressure back through the system via the egr . If i'm right a solid blanking plate will cause overboost - check engine light - and ultimately limp mode . As always i am happy to be corrected
If and when i get around to doing mine i will give some thought as to how i might block the egr altogether while allowing boost pressure to escape
without investigating the practicality of how it would work it could be piped straight to the exhaust i suppose ?
