- Nov 19, 2010
On my Collie not too surprisingly the diff lock on the rear axle was in a bad state so as I had a front 80 diff lock actuator like new on an axle I bought about 10 years ago and kept inside I thought ( knowing they are basically interchangeable) that I would swap it into the Collie rear as I am trying to get everything working as it should before I start to use it full time.
Has anyone done this before? apart from swapping the 80 plug for the 90 one do all the wires connect in the same positions or is there any wire swapping to do?
Seen better days!!
Seen better days!!
