Chris5-7chev
- Jun 9, 2011
Hi Clive, have only had a quick delve into Ben's posts so far but did spot the red Mk1 Cortina and yes the red car next to the old blue Ford Mustang is a Capri.
All good memories and all so simple to work on.
What isn't simple is this Landcruiser engine and box swop, the plan was to use the engine loom for the '95 24v and plug it into the '90 12v dash loom but am going away from this now mainly because I like to sleep at night..
Far too many multiplugs have been redesigned/changed between the years but the wire colours seem to be consistant so some splicing is on the cards later..
Lost loads of time last night stripping the engine down to change a leaking water pump but later realised the water drip was from one of the loosened alternator bracket bolts. After using the term 'FFS' a few times, just put the engine back together again..
Was in quite a mess;
There's double everything here with full wiring looms from 2 trucks;
Came out the garage at 11;00pm back in there at 07;00 and the front end is all rebuilt again so just wiring, fluids, bonnet etc to deal with.
You know how they say 'Don't try this at home'..............well I should have listened.
