80 Speedo Sensor for Cruise Control - cable adaptor doo dah
Cptsideways
Found the source of my non working cruise control, my speedo sensor is missing!
Its an early 80 so the sensor is in-line to the speedo cable, which screws into it. Should have an internal pin with it too. Sesnor has a 3 pin traingular plug on it.
If anyone has a spare transfer case about you might have one on it.
I can PM you a diagram of the bit I need if its helps but I think its fairly obvious, was only fitted to earlier 80's with CC.
Declan
