90 series 1KZ Torque Converter - Wanted
Beau
guyana
As above, looking for a torque converter for my cruiser. Anyone got one hanging about?
put a gearbox in it. the oil pump will be damaged. tc will not fix this alone. best bet would be karls box. then a separate transmission cooler large as you can. common problem this is. check the flexplate for cracking. seen this lots of times. if you do fix the box you will need an oil pump assembly and a good look inside the box. like i said best bet karls box straight in with upgraded cooler
What makes you think the oil pump will be damaged? It was not driven a lot once the odd noise came about, even though it would drive just fine. Gears all shifted fine, ect. And I already have a separate trans cooler bypassing the main radiator. Since doing that I never saw the AT light come back on during towing so it definitely worked well and has for many years.
Seen it before many times that's why. The bushing in the oil pump housing will be damaged. Like I say check your flex plate too for cracking
