HOPE THIS HELP YOU oil
Atsugi NVR140 Rotary Vane 200ml - OGX9801
Bosch/Behr DK14 type Rotary Vane 200ml - OGX9801
Calsonic DKV11D Swash Plate 185 + - 15ml OGX001 OGX9802
Calsonic DKV14C Swash Plate 185 + - 15ml OGX001 OGX9802
Centrola CPR series Rotary Vane 140ml - OGX9801
Centrola FS507, 508, 607 Swash Plate 130ml OGX001 OGX9802
Chrysler V2 Reciprocating - 2 cyl 227ml OGX001 OGX9802
Clarion CPR & CPW series Swash Plate - 10 cyl 140ml OGX001 OGX9802
Clarion Wankel Wankel Rotary 150ml - OGX9801
Delco (Frigidaire) A6 Swash Plate - 6 cyl 284ml OGX001 OGX9800
Delco (Frigidaire) R4 Rotary 4 cyl (axial) 170ml - OGX9800
Delco (Frigidaire) V5 V6 Wobble Plate 225ml OGX001 OGX9800
Delphi V5 V6 Wobble Plate 265ml OGX001 OGX9802
Delphi V5 Commodore Wobble Plate 220ml OGX001 OGX9802
Delphi V7 Commodore Wobble Plate 265ml OGX001 OGX9802
Denso 10P08E Swash Plate - 10 cyl 60 - 100ml OGX001 OGX9801
Denso 10P13A Swash Plate - 10 cyl 100ml OGX001 OGX9801
Denso 10P13C Swash Plate - 10 cyl 140 - 155ml OGX001 OGX9801
Denso 10P13E Swash Plate - 10 cyl 180 - 195ml OGX001 OGX9801
Denso 10P13F Swash Plate - 10 cyl 60 - 100ml OGX001 OGX9801
Denso 10P15C Swash Plate - 10 cyl 120 - 135ml OGX001 OGX9801
Denso 10P17C Swash Plate - 10 cyl 100 - 140ml OGX001 OGX9801
Denso 10P25C Swash Plate - 10 cyl 370 - 430ml OGX001 OGX9801
Denso 10P30C Swash Plate - 10 cyl 370 - 430ml OGX001 OGX9801
Denso 10PA15 Swash Plate - 10 cyl 100ml OGX001 OGX9801 80 series Landcruiser
Denso 10PA17 Swash Plate - 10 cyl 100ml OGX001 OGX9801 Landcruiser
Denso 2C90 Reciprocating - 2 cyl 240ml OGX001 OGX9802
Denso 2M110 Reciprocating - 2 cyl 190 - 230ml OGX001 OGX9802
Denso 2M110B Reciprocating - 2 cyl 190 - 230ml OGX001 OGX9802
Denso 500C Reciprocating - 6 cyl 1800ml OGX001 OGX9801
Denso 6D152 Swash Plate - 6 cyl 350ml OGX001 OGX9801
Denso 6E171A Swash Plate - 6 cyl 280ml OGX001 OGX9801
Denso 6P127A Swash Plate - 6 cyl 155ml OGX001 OGX9801
Denso 6P127D Swash Plate - 6 cyl 100ml OGX001 OGX9801
Denso 6P134 Swash Plate - 6 cyl 230ml OGX001 OGX9801
Denso 6P148 Swash Plate - 6 cyl 170ml OGX001 OGX9801
Denso 6P80C Swash Plate - 6 cyl 170ml OGX001 OGX9801
Denso 10P15E Swash Plate - 10 cyl 60 - 100ml OGX001 OGX9801
Denso 10P20C Swash Plate - 10 cyl 160 - 175ml OGX001 OGX9801
Denso 10P25B Swash Plate - 10 cyl 370 - 430ml OGX001 OGX9801
Denso 10P30B Swash Plate - 10 cyl 370 - 430ml OGX001 OGX9801
Denso 10PA13C Swash Plate - 10 cyl 100 - 140ml OGX001 OGX9801
Denso 10S13C Swash Plate - 10 cyl 100 - 115ml OGX001 OGX9801
Denso 10S15C Swash Plate - 10 cyl 120 - 135ml OGX001 OGX9801
Denso 10S20C Swash Plate - 10 cyl 180 - 195ml OGX001 OGX9801
Denso 10SR19 Swash Plate - 10 cyl 135 - 150ml OGX001 OGX9801
Denso 5SER09 Swash Plate - 5 cyl 60 - 75ml OGX001 OGX9801
Denso 6SEU14 Electronic Variable 90 - 105ml - OGX9802
Denso 6SEU16 Electronic Variable 130 - 145ml - OGX9802
Denso ES14C Hybrid 130 - 145ml - OGX011
Denso ES18C Hybrid 130 - 145ml - OGX011
Denso ES27C Hybrid 130 - 145ml - OGX011
Denso SC06E Scroll 45 - 85ml OGX001 OGX9801
Denso SCS06C Scroll 50 - 70ml OGX001 OGX9801
Denso SCSA06C Scroll 50 - 70ml OGX001 OGX9801
Denso SCSA08C Scroll 60 - 80ml OGX001 OGX9801
Denso SV07E Sliding Vane 80 - 100ml OGX001 OGX9801
Denso TV10CB Through Vane 120 - 160ml OGX001 OGX9801
Denso TV12C Through Vane 120 - 160ml OGX001 OGX9801
Denso TV12EC Through Vane 120 - 160ml OGX001 OGX9801
Denso TV14C Through Vane 120 - 160ml OGX001 OGX9801
Diesel Kiki DKS12 Swash Plate - 6 cyl 120ml OGX001 OGX9802
Diesel Kiki DKS13 Swash Plate - 6 cyl 120ml OGX001 OGX9802
Diesel Kiki DKS15 Swash Plate - 6 cyl 135ml OGX001 OGX9802
Hadsys TRF Turbo Rotary 135ml OGX001 OGX032
Hadsys TRF90 Style Turbo Rotary 135ml OGX001 OGX032
Halla Clim. Con. FS10, FX15 Swash Plate 170ml OGX001 OGX9802
Hitachi MJ123, MJ167 Swash Plate 200ml OGX001 OGX9802
Hitachi MJS130, MJ170 Swash Plate - 6 cyl 170ml OGX001 OGX9802
Hitachi SWP123, SWP167 Swash Plate 250ml OGX001 OGX9802
Keihin AN150, CN150 Radial 150ml OGX001 OGX9801
Matsushita S1150 Rotary Vane 135ml OGX001 OGX9801
MHI MSC90 Swash Plate 120ml OGX001 OGX9801
MHI MSC105 Swash Plate 130ml OGX001 OGX9801
MHI MSC130 Swash Plate 240ml OGX001 OGX9801
Nihon NVR140 Rotary Vane 200ml OGX001 OGX9801
Panasonic N1300, N1500 Rotary Vane 135ml OGX001 OGX9801
Panasonic SA1150AA R12 Rotary Vane 135ml OGX001 OGX9801
Panasonic SA1150AA R134a Rotary Vane 135ml OGX001 OGX9801
Sanden SD5H09 Wobble Plate - 5 cyl 100ml OGX001 OGX031
Sanden SD505 Wobble Plate - 5 cyl 100ml OGX001 OGX032
Sanden SD507 Wobble Plate - 5 cyl 135ml OGX001 OGX032
Sanden SD508 Wobble Plate - 5 cyl 175ml OGX001 OGX032
Sanden SD510 Wobble Plate - 5 cyl 135ml OGX001 OGX032
Sanden SD5H14 Wobble Plate - 5 cyl 175ml OGX001 OGX031
Sanden SD708, SD709 Wobble Plate - 7 cyl 135ml OGX001 OGX032
Sanden SD7B10 Wobble Plate - 7 cyl 150ml OGX001 OGX031
Sanden SD7H10 Wobble Plate - 7 cyl 150ml OGX001 OGX031
Sanden SD7H13 Wobble Plate - 7 cyl 135ml OGX001 OGX032
Sanden SD7H15 Series 4, 7 Wobble Plate - 7 cyl 135ml - 300ml OGX001 OGX032
Sanden SD7H15 Series 8 Wobble Plate - 7 cyl 135ml - 240ml OGX001 OGX031
Sanden TR105 Turbo Rotary 130ml - 150ml OGX001 OGX031
Sanden TR105 Accum System Turbo Rotary 220ml OGX001 OGX031
Sanden TR70 Turbo Rotary 150ml OGX001 OGX031
Sanden TR90 Turbo Rotary 150ml OGX001 OGX031
Sanden TRF508 Turbo Rotary 120ml OGX001 OGX031
Sanden SD6V12 Variable 135ml OGX001 OGX031
Sanden SD7V12 Variable 135ml OGX001 OGX031
Sanden SD7V16 Variable 135ml OGX001 OGX031
Sanden SDB705 Wobble Plate - 7 cyl 50ml OGX001 OGX031
Sanden TRS090 Turbo Rotary 120ml - 150ml OGX001 OGX031
Seiko Seiki SS110, 850, 140, 170 PSV Rotary 200ml OGX001 OGX9801
Seiko Seiki SS110P Rotary 170ml OGX001 OGX9801
Seiko Seiki SS140P, SS170P Rotary 200ml OGX001 OGX9801
Seiko Seiki SS805T, SS806T Rotary 150ml OGX001 OGX9801
Seltec TM - 13 Swash Plate - 6 cyl 130ml OGX001 OGX9802
Seltec TM - 15 Swash Plate - 6 cyl 150ml OGX001 OGX9802
Seltec TM - 16 Swash Plate - 6 cyl 180ml OGX001 OGX9802
Tama TM - 08 Swash Plate - 6 cyl 150ml OGX001 OGX9802
Tama TM - 13 Swash Plate - 6 cyl 150ml OGX001 OGX9802
Tama TM - 14 Swash Plate - 6 cyl 150ml OGX001 OGX9802
Tama TM - 16 Swash Plate - 6 cyl 180ml OGX001 OGX9802
Tama TM - 26 Swash Plate - 6 cyl 600ml OGX001 OGX9802
Tama TM - 32 Swash Plate - 6 cyl 600ml OGX001 OGX9802
Tecumseh HG1000 Reciprocating - 2 cyl 320ml OGX001 OGX9802
Unicla DA299, DC120 Reciprocating - 2 cyl 260ml OGX001 OGX1040
Unicla UP108 Swash Plate - 10 cyl 150ml OGX001 OGX1040
Unicla UPS105, UPS107 Swash Plate - 10 cyl 140ml OGX001 OGX1040
Unicla UPS109 Swash Plate - 10 cyl 150ml OGX001 OGX1040
York 206 (6”), 209 (9”) Reciprocating - 2 cyl 285ml OGX001 OGX9802
York 210 (10”) Reciprocating - 2 cyl 341ml OGX001 OGX9802
York E209, E210 Reciprocating - 2 cyl 341ml OGX001 OGX9802
Zexel (Diesel Kiki) DCW Wobble Plate 225ml OGX001 OGX9802
Zexel (Diesel Kiki) DCW - 17 Wobble Plate 200ml OGX001 OGX9802
Zexel (Diesel Kiki) DKS - 12, DKS - 15 Swash Plate - 6 cyl 150ml OGX001 OGX9802
Zexel (Diesel Kiki) DKS - 16, DKS - 17 Swash Plate - 6 cyl 200ml OGX001 OGX9802
Zexel (Diesel Kiki) DKV - 14C Rotary Vane 200ml OGX001 OGX9801
Zexel (Diesel Kiki) DKV - 14D Rotary Vane 200ml OGX001 OGX9801
