knicko
- Dec 23, 2012
Whilst replacing upper and lower front ball joints (still ongoing actually...) I think I may have inadvertently pulled the front driveshafts out on both sides.
I had already replaced the lower ball joints and track rod ends, and hand tightened both, so the bottom of the hub was held in place, but I had the top arms off the upper wishbones. As I pulled the arm outwards to get some room to work on removing the upper ball joints, the driveshaft felt like it slipped out of its splines. The inner driveshaft boot stretched out but remained in place.
I pushed the hub back inwards and wiggled the driveshaft by hand to line up the splines and it all appears ok, I think.
This happened on both the N/S and O/S.
I am wondering whether this will have popped oil seals or some other unseen problem.
Still fighting with the upper ball joints so can't test drive the vehicle at this point.
Can anyone advise please?
