all on and together.
Not 100% happy with the fit but it will do for mot, it'll probably look a lot better when the bonnet is painted to be fair.
For anyone interested, the scuttle is easy peasy to remove, and can (just) be done with the bonnet on.
Six screws along the bulkhead joint, I used a right angled driver to crack them then just by hand with a driver bit.
Once done, making sure you have removed the wipers, slide the scuttle forward towards the engine. There are six clips, two at the wings, and four under the screen. For the wing ones, you want a little flat-blade for each side, lever the "wing" of the clip towards the centreline of the scuttle, it will ease the sprung part out of the slot. As you pull the scuttle forward, hopefully it will release from the rear clips without breaking them. I didn't know how to do it so attempted to take the bottom screen trim off, breaking the clips. A full set of six was £47 with my discount, absolute robbery for what they are, but they have to be 100% for the scuttle to fit and the screen trim to go back on (if you even take it off). That was a lesson.....
