Errol Reid
- Apr 5, 2018
Is is possible to fit air conditioning in a BJ73? Anyone tried it?
I fitted aircon to my UK LJ70.
All the components inside the cab are the same across all 70 series models (up to when they changed the dash from metal to plastic).
So the evaporator, controls, small wiring loom with little black electrical box, should be easy to source and fit. The wiring loom and controls will plug straight into your loom.
The pipes in the engine bay can always be made up by any hose place, if you struggle to source the correct ones.
The condenser shouldnt be too hard to source as a much more common 75 series one will bolt straight on (in fact you could get all the components from a 75 and Toyota sold hundreds of thousands of them down here).
Then its just the compressor and mounting bracket you will need to source for your engine.
There is normally a single wire in the engine bay, even on non aircon models, which goes to the compressor once fitted to the engine.
Fitting aircon to a non aircon 70 really isnt that difficult or that complex once you get the bits.
Make sure if fitting second hand pipes/hoses to use new O rings and they will need a little smear of aircon oil on them when fitting. The compressor will also need some oil in it but I just left that up to the aircon place who flushed my system then refilled it with oil, gas and dye. Its worth paying a little extra for the dye as it makes finding any leaks super easy!
Thanks for the help Ben.
This should give me a head start, I'm just looking around for the bits right now, going to start collecting.
Errol, is your BJ a 12volt or a 24 volt?
the 24volt airco ecu is very difficult to source but you can do a workaround with a 12 volt ecu, a 24-12 convertor and 2 relays. I did this with my HZJ75
Not so fast now! There’s 80 series with two batteries that sit at 12v until the key is turned and then start at 24v and others that have two batteries permanently connected at 12v plus the 24v setup. Post up a photo of the connections overall and we can have a look. Also your headlamps should be marked 12v or 24v on top of the moulding if they’re anything like the 80 series.It has 2 batteries, so I am going to assume that is a 24 volt version.... No manual
View attachment 143033 12 volt ac in 24 volt system :
I put the converter and the relays in the glove box. The amplifier and the connector are just behind it.
