Graham
Hi All,
When I got back to my LC after 12 months, I found the air-con was blowing warm only.
So I gave Kwik-Fit a call, they said bring it along.
£49.99 sounded a good deal for a re-gas.
So following morning, arrived at KF, and they hooked up there machine, and sucked out what remaining gas was left.
After 10 minutes or so, the machine pulls an almost vacuum, and shuts the valves, and holds it for 5 minutes, to determine if there is a leak.
After 5 minutes, the vacuum was still 100%, indicating no leak.
So the new oil, and new gas are introduced, and 10 minutes later, he starts the engine, and the air con is sub zero cold
Next day I didn't try it, as it wasn't a warm day, and also I had forgotten about it, more to be honest.
So a few days later heading down through France, I decide it's "air-con" time.
And all I got was warm air
So, now I am confused, the 5 minute "hold" test proved no leak, but that was with the engine not running.
I feel it may have lost the gas again, when the engine is running?
Is that possible that when the engine is not running, there is no leak, but when the engine is running, the gas escapes via the compressor seals?
Gra.
Gra.
