- Feb 24, 2010
No I don't mean going bald
My on board air system looses about 15psi every 5 minutes, I know this because my pump is designed to 'kick in' at 135psi and 'shut off' at 150psi, if left on this is what it does every 5 minutes.
Is this acceptable air loss, or as I suspect, have I not done a good enough job of sealing the fittings? I used PTFE tape on all the screw in fittings and all the push in fittings I assumed should be self sealing
